| Version: | V8i, CONNECT | ||
| Area: | Text | ||
| Subarea: | General |
How to make annotations appear in all views when placing text in a 3d model.
1. After placing a note, select the Element Information tool and then select the text.
2. In the Element Information dialog box, change the View Dependent setting to View Independent.
Now the text displays regardless of view orientation.
