1. IS 456 code_Beam Design_Crack-width check_validation document
Beam_IS code_Crackwidth_Validation
2. Shear Wall design with Boundary Element_IS 456 + IS 13920 2016
Shear Wall Design - Boundary Element_IS 13920-2016
3. Shear Wall design with Boundary Element_IS 456 + IS 13920 2016 (With Slenderness Effect + Shear Reinforcement)
Shear Wall Design_Boundary Element_Slender and Shear design_Validation Sheet
4. Beam Design_Non Ductile Validation sheet
B6_Design calculation_Validation Sheet
5. Beam - Ductile - Sway shear calculation
IS 456 + 13920_Beam Sway Shear calculation_R0
6. Ductile Column Design_Validation sheet
IS code_Column Design_Ductile_Validation Sheet
7. Pilecap design_3 piles_Validation sheet
IS_PC23_Pilecap Design_3piles_Validation sheet
8. Column Beam Joint check
Column Beam Joint Check Validation Document_IS 13920-2016
9. Column effective length factor calculation
Column_IS code_Effective Length factor_Validation sheet
10. Coupling Beam Diagonal Reinforcement as per IS 13920-2016
Coupler Beam_design calculation_R0
11. Column Crack Width Validation sheet - column with Axial force and Biaxial Moments
IS code-Crack Width-Validation sheet
