[[Footing Design with loss of contact condition in RCDC]]
[[Base pressure calculation in RCDC]]
[[How the effective self-weight of the footing is calculated?]]
[[For calculation of two way (punching) shear, footing self-weight is not added to axial load.]]
[[As per design, required reinforcement is 1478/1528 sqmm along L/B direction. Provided reinforcement is T12@175 mm which amounts to 1453 sqmm only for 2.25 m width of footing, whereas the calculation report shows Ast provided as 1583sqmm. Please clarify.]]
[[Please clarify the footing type “on raft” given in RCDC.]]
[[How is the volume of trapezoidal footing calculated in RCDC?]]
[[RCDC Footing minimum reinforcement]]
[[Trying to Make footing square in RCDC]]
[[Reaction mismatch between RCDC and STAAD for footing design]]
