| Version: | V8i, CONNECT | ||
| Area: | Text | ||
| Subarea: | Fields |
How to change the order through which enter data files (EDF) are cycled with the Auto Fill In Enter Data Fields tool.
When running the Auto Fill In Enter Data Fields tool it starts with the first data field placed in the file and ends with the last placed. You can change its "file position" by selecting the data field and running this keyin:
wset add;wset drop
The data field selected prior to running that keyin will be considered the last data field placed in the file and its "file position" number will change accordingly. You can see its new number by performing an Element ID on the data field and going to the Details.
