| Product(s): | MicroStation |
| Version(s): | 08.11.09.xxx, 10.xx.xx.xxx |
| Environment: | N\A |
| Area: | Other |
| Subarea: | N\A |
Can a specific webpage be called through a customized menu or button?
Yes, use the following key-in in the menu.
MDL LOAD WEBBROWS <BROWSE URL>
For Example:
MDL LOAD WEBBROWS www.bentley.com
