| Version: | V8, XM, V8i, CONNECT | ||
| Area: | Visualization | ||
| Subarea: | Lights |
How can I control the brightness of RPCs without adjusting the brightness slider?
Apply a material to the Color / Level combination that the RPC(s) is using.
This will allow the ability to adjust the brightness (among other things) for the RPC(s).
Notes:
This is useful when the scene has the correct brightness, but the RPC(s) do not.
