| Version(s): | All | ||
| Area: | OpenSTAAD | ||
| Subarea: | Analysis Result, Output | ||
| Original Author: | Bentley Technical Support Group, Shreyanka Bhattacharjee | ||
Problem Description:
How to extract Node Displacement for all Load Combination Cases using OpenSTAAD (VBA and python)
Parameter Details are available in OpenSTAAD Help Manual
Sample VBA Syntax:
communities.bentley.com/.../Extract-Nodal-Displacement-for-Load-Combination.xlsm
Python script:
communities.bentley.com/.../GetNodeDisplacements.py
