| Version: | 08.11.09. XXX or 10.XX.XX.XX | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles |
How to change the location of the radius symbol so that it is in the front and not behind the actual radius.
Element > Dimension Styles > Tools Settings > Radius > Set the prefix to the radius symbol and then the R will be in the front as opposed to behind it.
