| Version: |
08.11.09.xxx, 10.xx.xx.xxx | ||
| Area: | DWG | ||
| Subarea: | Open |
Cannot open DWG settings dialog
dwgsettings.ma file is missing or bad.
Dwgsettings.ma should be found by configuration variable "_USTN_REQUIREDAPPS"
The default location is for V8 2004 and V8 XM:
...\MicroStation\mdlsys\required\
For V8i and V8i (SELECTseries):
...\MicroStation\mdlsys\asneeded\
Move dwgsettings.ma into the a search path of "_USTN_REQUIREDAPPS".
Or,
Replace the file from a known good installation
