List of critical and high severity defects identified in STAAD.Pro V2023 build 23.00.03.25
| Issue ID | Title | Severity | 1st affected Build | Fixed in Build |
| A-524650 | Member section displacement results do not account for lateral releases on members | 2 - High | 20.07.04.12 | Known Issue |
| A-946144 | IS 800:2007 (LSD/WSD): Design forces swapped when IY>IZ in IS 800:2007 LSD./WSD design | 2 - High | 22.10.00.153 | 24.00.02.354 |
| A-1221514 | Wind Load Panel Formation affected by support nodes | 1 - Critical | 20.07.04.12 | 24.00.02.354 |
| A-1271381 | AS4100-1998 : Physical member design | 2 - High | 20.07.09.31 | 24.00.00.577 |
| A-1335471 | EN 1993-1-1-2005 : Incorrect warping constant values evaluated for Tube and Angle profiles | 2 - High | 20.07.10.41 | 24.00.00.577 |
| A-807595 | NRC 2005/2010: Incorrect assignment of FV parameter | 2 - High | 21.00.00.57 | 24.00.00.577 |
| A-1347586 | AS4100-1998: Incorrect Section slenderness (λe) | 1 - Critical | 20.07.07.19 | 24.00.00.577 |
| A-1391778 | EN 1993-1-1 : Reduction in web depth for wide flange profiles | 2 - High | 23.00.02.361 | 24.00.00.577 |
| A-1419270 | AISC 341-16 : Web stiffener parameters | 2 - High | 21.00.02.30 | 24.00.00.577 |
| A-1392128 | Design code parameters conflicting with other codes | 2 - High | 20.07.10.41 | 24.00.00.577 |
| A-1373774 | NZS3404-1997: Angle profile slenderness limit (λey) | 1 - Critical | 21.00.00.57 | 24.00.00.577 |
| A-1341242 | IS800-2007 LSD : Selection of double profiles with spacing | 2 - High | 22.11.00.156 | 24.00.00.577 |
| A-1427565 | Self-weight distribution for quadrilateral plates | 2 - High | 20.07.04.12 | 24.00.00.577 |
| A-1431170 | AIJ 2002/2005: Interaction Checks | 2 - High | 21.03.00.146 | 24.00.02.354 |
| A-1500567 | AISC 360-16: Incorrect H2-1 at the Heel of an Equal Angle | 1 - Critical | 21.00.02.44 | 24.00.02.354 |
| A-1482280 | AS4100-1998/2020: Shear capacity for circular profiles | 2 - High | 20.07.07.19 | 24.00.02.354 |
| A-1479249 | Design of tapered members to Chinese Steel Design code GB50017-2017 | 1 - Critical | 23.00.02.361 | 24.00.02.354 |
| A-1496086 | CSA S16-19: Incorrect evaluation of Critical Elastic Moment | 2 - High | 22.08.00.175 | 24.00.02.354 |
| A-1540805 | EN 1993-1-1: 2005 : Torsion checks are not performed when Mx is zero at the member start | 1 - Critical | 23.00.02.361 | 24.00.02.354 |
| A-1543790 | AISC 360 & CSA S16: Incorrect minor axis bending capacity for channel profiles | 1 - Critical | 20.07.08.22 | 24.00.02.354 |
| A-1547404 | AISC 360-05/10/16/22: Incorrect design wall thickness for HSS profiles | 1 - Critical | 20.07.04.12 | 24.00.02.354 |
| A-1548004 | AISC 360-16/22: Incorrect effective area for a slender round HSS profile | 1 - Critical | 21.00.01.12 | 24.00.02.354 |
| A-1559731 | AISC 360-16/22: Incorrect calculation of Cb for single angle profiles | 1 - Critical | 21.00.01.12 | 24.00.02.354 |
| A-807812 | Cold formed design: Russian cold formed pipe profiles | 2 - High | 20.07.04.12 | 24.00.02.354 |
| A-488029 | Incorrect wind loads on open structures for single angle profiles | 1 - Critical | 20.07.04.12 | 24.00.02.354 |
| A-937039 | Incorrect wind pressures on open structures | 1 - Critical | 20.07.04.12 | 24.00.02.354 |
| A-1100215 | Incorrect wind pressures on closed panels | 1 - Critical | 20.07.04.12 | 24.00.02.354 |
| A-1398892 | Inaccurate wind panel validation | 1 - Critical | 20.07.07.32 | 24.00.02.354 |
| A-1470822 | AISI-2016 and AS4600-2018 : Incorrect effective section properties | 1 - Critical | 22.04.00.40 | 24.00.02.354 |
| A-1572162 | CSA S16-19: Incorrect bending capacity for Class 3/4 profile as per Cl.13.5(b)/(c) | 2 - High | 22.08.00.175 | 24.00.02.354 |
| A-1484993 | Incorrect Zone Loading on Members with Beta Angle | 1 - Critical | 23.00.00.345 | 25.00.00.539 |
| A-1568149 | Mass overestimation due to improper load placement in dynamic load | 1 - Critical | 20.07.08.20 | 25.00.00.539 |
| A-1674513 | AISC 360-16/22: Incorrect interaction ratio reported when both H1.1 and H1.3 apply | 1 - Critical | 21.00.01.12 | 25.00.00.539 |
| A-1667479 | IS800-2007 (LSD): Incorrect λLT Calculation for Wide Flange Profiles | 1 - Critical | 20.07.06.23 | 25.00.00.539 |
| A-1674510 | AS 4100: Incorrect bi-axial interaction check when axial limit governs (Clause 8.4.5) | 1 - Critical | 20.07.04.12 | 25.00.00.539 |
| A-1708628 | AISC 360-16/22 : Double Channel Front-to Front specification | 2 - High | 21.00.01.12 | 25.00.01.424 |
| A-1708762 | Mexican Legacy Database | 2 - High | 20.07.04.12 | 25.00.01.424 |
| A-1716778 | EN 1993-1-1: Incorrect Section Classification | 1 - Critical | 20.07.06.23 | 25.00.01.424 |
| A-1716791 | EN 1993-1-1 2005 : Effective Section Properties of Wide Flange Sections | 1 - Critical | 23.00.02.361 | 25.00.01.424 |
| A-1468910 | Self weight loading on plates with variable thickness | 2 - High | 20.07.04.12 | 25.00.01.424 |
| A-1708447 | AISC 360-2016 and 2022: Double Unequal Angles with Short Legs Connected | 2 - High | 21.00.01.12 | 25.00.01.424 |
| A-1739410 | NRC/NBCC 2010: Incorrect Evaluation of Minimum and Maximum Base Shear for Static Seismic Loading | 1 - Critical | 21.00.00.57 | 25.00.01.424 |
| A-1739748 | Steady State Analysis: Applied Joint Moments | 1 - Critical | 21.03.00.146 | 25.00.01.424 |
| A-1929912 | AISC 360-16/22: Incorrect LTB for Tee and Double-Angle | 1 - Critical | 21.00.01.12 | 25.00.01.424 |
| A-1708470 | Deflection Checks On Cantilevers Including Load Cases With No Local Deflection | 2 - High | 22.08.00.175 | 25.00.01.424 |
| A-2007070 | Time History defined with harmonic forcing function having non-zero phase angle | 1 - Critical | 22.12.00.142 | 26.00.00.340 |
| A-1988266 | Seismic self weight calculation for very short tapered I profiles | 2 - High | 21.00.02.30 | 26.00.01.491 |
| A-2038944 | Incorrect member design forces using an SRSS combination | 1 - Critical | 21.00.00.57 | 26.00.00.340 |
| A-2084603 | AS4100 (1998/2020): Incorrect web slenderness limit for Tee profiles | 1 - Critical | 20.07.04.12 | 26.00.01.491 |
| A-2094654 | AISC 360-16/22: Incorrect default SNUG value for built-up members | 1 - Critical | 21.00.02.30 | 26.00.01.491 |
| A-2106652 | CSA S16-09/14: Limiting value of Factored Moment Resistance (Mr) as per Clause 13.6(a)(i) | 1 - Critical | 20.07.10.41 | 26.00.01.491 |
| A-2009553 | Wind Load assignment Combining RANGE and LIST methods | 2 - High | 20.07.04.12 | 26.00.01.491 |
| A-2016637 | AISC ASD: Incorrect Section Modulus used in design of multiple angle profiles | 1 - Critical | 20.07.08.22 | 26.00.01.491 |
| A-2017394 | Local deflection checks of models distant from the global origin | 2 - High | 20.07.04.12 | 26.00.01.491 |
| A-2024531 | Incorrect open-structure wind loading for angle profiles | 1 - Critical | 20.07.04.12 | 26.00.01.491 |
| A-2092167 | Incorrect processing of floor load within a reference load case | 1 - Critical | 20.07.08.20 | 26.00.01.491 |
| A-2011909 | EN1993-1-1-2005: Section classification check is skipped | 2 - High | 20.07.06.23 | 26.00.01.491 |
| A-2125826 | IS 1893 (Part 1) 2016: Incorrect static base shear used for comparison with response spectrum base shear | 2 - High | 21.03.00.146 | 26.00.01.491 |
| A-2017710 | Enclosed Zone Load with disconnected regions | 2 - High | 23.00.00.345 | 26.00.01.491 |
| A-1996410 | AS 4100-1998/2020: Reference Buckling Moment underestimated for UPT wide-flange profiles | 2 - High | 23.00.02.361 | 26.00.01.491 |
