STAAD.Pro 22.05.00.131 / 22.05.00.148
List of critical and high severity defects identified in STAAD.Pro V22 build 22.05.00.131 / 22.05.00.148
Issue ID Title Severity 1st affected Build Fixed in Build
A-487590 Nonlinear Analysis - plate results reported as zero for model with multiple load cases 2 - High 22.01.00.39 22.06.00.138
A-487670 Incorrect base shear being generated as per Equivalent Lateral Force Method using IBC 2018 2 - High 22.02.00.26 22.10.00.153
A-487690 Incorrect design results for square tapered section using AISC 360 16 2 - High 22.03.00.28 22.07.00.160
A-487732 Incorrect Warping Constant used during selection of wide flange profiles as per AISC 360-16 2 - High 21.00.02.44 22.07.00.160
A-487738 Incorrect design as per AS4100 for a braced physical member having analytical node at any quarter point along its length 2 - High 21.00.02.44 22.06.00.138
A-487742 Error in torsion design for beams per ACI 318-2011 2 - High 20.07.11.50 22.06.00.138
A-505266 Incorrect Warping Constant used during selection of wide flange profiles as per CAN/CSA-S16-14 or CAN/CSA-S16-09 2 - High 21.00.02.30 22.06.00.138
A-506489 Incorrect Warping Constant used during selection of wide flange profiles as per IS 800 2007 (LSD/ WSD) 2 - High 21.00.02.30 22.06.00.138
A-507231 Incorrect Warping Constant used during selection of Hat section as per AISI 2016 2 - High 22.04.00.40 22.07.00.160
A-511125 Incorrect Warping Constant used during selection of Channel profiles as per EN 1993-1-1 2005 or BS EN 1993-1-1 2005 2 - High 20.07.11.70 22.07.00.160
A-515693 Member assigned with MEMBER TENSION and subjected to axial tension - is designed as a compression member with NZS3404-1997 code 2 - High 21.00.00.57 22.06.00.138
A-524650 Member section displacement results do not account for lateral releases on members 2 - High 20.07.04.12 Known Issue
A-530329 Flexural capacity for local buckling about minor axis is incorrectly evaluated for Channel and Channel with lips sections as per AISI 2016 2 - High 22.04.00.40 22.06.00.138
A-532805 Lateral torsional buckling capacity about major axis is incorrectly evaluated for Channel section as per AISI 2016 2 - High 22.04.00.40 22.06.00.138
A-533716 The horizontal seismic influence coefficient (ALPHA) is incorrect for period from 0.1s to Tg as per GB50011-2001 2 - High 20.07.06.23 22.06.00.138
A-545710 Section Modulus of angles designed to AISI 2016 2 - High 22.04.00.40 22.06.00.138
A-547383 IS801 compression capacity check for multiple properties 2 - High 22.01.00.39 22.06.00.138
A-547591 AISI 2016 design with LOAD LIST ALL 2 - High 22.04.00.40 22.06.00.138
A-554981 NZS 3404:1997 slenderness for tension members 2 - High 21.00.00.57 22.07.00.160
A-561450 IS 800 :2007 LSD Single Angle slenderness check 2 - High 22.05.00.131 22.07.00.160
A-577472 SP 16 2017/2011 : Tube design 2 - High 22.04.00.40 22.07.00.160
A-633034 NZS 3404-1997 : Clause 5.12.2 2 - High 21.00.00.57 22.07.00.160
A-669073 AISC 360-16: Warping constant is used in the calculation of Euler Buckling Stress for T & 2L Sections 2 - High 21.00.02.44 22.08.00.175
A-698135 SANS 10162-1 : UNT and UNB parameters 2 - High 20.07.11.33 22.09.00.115
A-710597 EN 1993-1-1: 2005 : Utilization ratio as per Eq.6.62 for Slender Tee section 2 - High 20.07.07.19 22.08.00.175
A-716046 EN 1993-1-1: 2005 : Shift of neutral axis for Slender Tee section 2 - High 20.07.07.19 22.08.00.175
A-774908 AISC 360-16: Effect of eccentricity for single angle profiles 2 - High 22.02.00.26 22.09.00.115
A-784278 AISC N690 1984: Shear design for pipe sections 2 - High 20.07.06.23 22.09.00.115
A-813848 Unbraced length : UNF and UNL Parameters 2 - High 20.07.08.32 22.10.00.153
A-817499 EN 1993-1-1:2005 : LEG parameter for single angle profiles 2 - High 20.07.07.32 22.11.00.156
A-852094 AISC 360-16 : FY and FU not considered from assigned material 2 - High 21.00.02.44 22.10.00.180
A-865805 Incorrect ELFP Torsional Moment : Optional Load Factor Multiplication 2 - High 22.01.00.39 22.10.00.180
A-865842 AISC 341-16 : Incorrect Seismic Classification for Custom Steel 2 - High 22.01.00.39 22.10.00.180
A-935629 AISC 360-16: SGR parameter 2 - High 21.00.02.44 22.12.00.142
A-969825 AISC 360-10/05 : Combined flexure and tension 2 - High 20.07.11.50 22.12.00.142
A-973697 AS4100-1998 : Moment modification factor 2 - High 20.07.11.90 23.00.00.345
A-1003677 NZS-3404-1997 : Physical member design 2 - High 21.00.00.57 23.00.00.345
A-1005695 NZS-3404-1997 : Analytical Member Design 2 - High 21.00.00.57 23.00.00.345
A-1015058 AISI 2016 : Deflection checks 2 - High 22.04.00.40 23.00.00.345
A-1032348 AISC 360-16 and BS5950 Pt 1 : Incorrect shear capacity parallel to the flanges for Double Channel profiles  2 - High 21.00.02.30 23.00.00.345
A-999611 Incorrect Time History analysis results with a Harmonic Ground motion  2 - High 20.07.04.12 22.12.00.142
A-996557 IS800:1984: Properties determined by incorrect CG position  2 - High 22.05.00.131 23.00.00.345
A-1073141 IBC 2012/2015/2018: Failure to process negative accidental eccentricity factor in Response Spectrum Analysis  1 - Critical 20.07.11.33 23.00.00.345
A-1121536 EN 1993-1-1:2005 : Failure to perform Bending Check (Clause 6.2.5) and Buckling Check (Equations 6.3.3-661, 662)  1 - Critical 20.07.11.90 23.00.00.345
A-1176400 AISC 360-05/10: Slenderness of Single Angle  2 - High 20.07.11.50 23.00.02.361
A-1199138 AISC 360-16: Incorrect H2-1 at the Heel of an Equal Angle  2 - High 21.00.02.44 23.00.00.345
A-1221514 Wind Load Panel Formation affected by support nodes  1 - Critical 20.07.04.12 24.00.02.354
A-1225794 AS4100-1998 & NZS 3404 -1997: Reference buckling moment for wide flange profiles with unequal flanges  2 - High 20.07.11.90 23.00.02.361
A-1232633 CSA S16-09/14/19: Incorrect Evaluation of Factored Moment Resistance  1 - Critical 20.07.10.64 23.00.02.361
A-1247472 AS4100-1998 : Member moment capacity checks as per Clauses 8.4.2.2 and 8.4.4.1  2 - High 20.07.11.90 23.00.02.361
A-1271381 AS4100-1998 : Physical member design  2 - High 20.07.09.31 24.00.00.577
A-487774 Inclined Joint load using ref Joint  2 - High 20.07.04.12 23.00.02.361
A-487893 Wind load on open structures are incorrectly evaluated on members with beta angles  2 - High 20.07.04.12 23.00.02.361
A-1327542 EN 1993-1-1:2005 : Cl 6.2.2.4 not implemented for I section with Class 3 web and Class 1 or 2 Flange  2 - High 20.07.10.41 23.00.02.361
A-995133 IS 800 2007 (LSD/WSD) : Section classification for Welded Section T Profile  2 - High 20.07.06.23 23.00.02.361
A-1335471 EN 1993-1-1-2005 : Incorrect warping constant values evaluated for Tube and Angle profiles  2 - High 20.07.10.41 24.00.00.577
A-1352814 Time History Analysis: Plate stresses ignore missing mass  2 - High 20.07.10.41 23.00.03.25
A-1350894 AISC 360-05/10/16: Incorrect slenderness for single angles  1 - Critical 20.07.04.12 23.00.03.25
A-807595 NRC 2005/2010: Incorrect assignment of FV parameter  2 - High 21.00.00.57 24.00.00.577
A-1347586 AS4100-1998: Incorrect Section slenderness (λe)  1 - Critical 20.07.07.19 24.00.00.577
A-846868 Incorrect design shear area  2 - High 20.07.04.12 22.12.00.142
A-1419270 AISC 341-16 : Web stiffener parameters  2 - High 21.00.02.30 24.00.00.577
A-1392128 Design code parameters conflicting with other codes  2 - High 20.07.10.41 24.00.00.577
A-1373774 NZS3404-1997: Angle profile slenderness limit (λey)  1 - Critical 21.00.00.57 24.00.00.577
A-1427565 Self-weight distribution for quadrilateral plates  2 - High 20.07.04.12 24.00.00.577
A-1431170 AIJ 2002/2005: Interaction Checks  2 - High 21.03.00.146 24.00.02.354
A-1500567 AISC 360-16: Incorrect H2-1 at the Heel of an Equal Angle  1 - Critical 21.00.02.44 24.00.02.354
A-1482280 AS4100-1998/2020: Shear capacity for circular profiles  2 - High 20.07.07.19 24.00.02.354
A-1543790 AISC 360 & CSA S16: Incorrect minor axis bending capacity for channel profiles  1 - Critical 20.07.08.22 24.00.02.354
A-1547404 AISC 360-05/10/16/22: Incorrect design wall thickness for HSS profiles  1 - Critical 20.07.04.12 24.00.02.354
A-1548004 AISC 360-16/22: Incorrect effective area for a slender round HSS profile  1 - Critical 21.00.01.12 24.00.02.354
A-1559731 AISC 360-16/22: Incorrect calculation of Cb for single angle profiles  1 - Critical 21.00.01.12 24.00.02.354
A-807812 Cold formed design: Russian cold formed pipe profiles  2 - High 20.07.04.12 24.00.02.354
A-488029 Incorrect wind loads on open structures for single angle profiles  1 - Critical 20.07.04.12 24.00.02.354
A-937039 Incorrect wind pressures on open structures  1 - Critical 20.07.04.12 24.00.02.354
A-1100215 Incorrect wind pressures on closed panels  1 - Critical 20.07.04.12 24.00.02.354
A-1398892 Inaccurate wind panel validation  1 - Critical 20.07.07.32 24.00.02.354
A-1470822 AISI-2016 and AS4600-2018 : Incorrect effective section properties  1 - Critical 22.04.00.40 24.00.02.354
A-1568149 Mass overestimation due to improper load placement in dynamic load  1 - Critical 20.07.08.20 25.00.00.539
A-1674513 AISC 360-16/22: Incorrect interaction ratio reported when both H1.1 and H1.3 apply  1 - Critical 21.00.01.12 25.00.00.539
A-1667479 IS800-2007 (LSD): Incorrect λLT Calculation for Wide Flange Profiles  1 - Critical 20.07.06.23 25.00.00.539
A-1674510 AS 4100: Incorrect bi-axial interaction check when axial limit governs (Clause 8.4.5)  1 - Critical 20.07.04.12 25.00.00.539
A-1708628 AISC 360-16/22 : Double Channel Front-to Front specification  2 - High 21.00.01.12 25.00.01.424
A-1708762 Mexican Legacy Database  2 - High 20.07.04.12 25.00.01.424
A-1716778 EN 1993-1-1: Incorrect Section Classification  1 - Critical 20.07.06.23 25.00.01.424
A-1468910 Self weight loading on plates with variable thickness  2 - High 20.07.04.12 25.00.01.424
A-1708447 AISC 360-2016 and 2022: Double Unequal Angles with Short Legs Connected  2 - High 21.00.01.12 25.00.01.424
A-1739410 NRC/NBCC 2010: Incorrect Evaluation of Minimum and Maximum Base Shear for Static Seismic Loading  1 - Critical 21.00.00.57 25.00.01.424
A-1739748 Steady State Analysis: Applied Joint Moments  1 - Critical 21.03.00.146 25.00.01.424
A-1929912 AISC 360-16/22: Incorrect LTB for Tee and Double-Angle  1 - Critical 21.00.01.12 25.00.01.424
A-1988266 Seismic self weight calculation for very short tapered I profiles  2 - High 21.00.02.30 26.00.01.491
A-2038944 Incorrect member design forces using an SRSS combination  1 - Critical 21.00.00.57 26.00.00.340
A-2084603 AS4100 (1998/2020): Incorrect web slenderness limit for Tee profiles  1 - Critical 20.07.04.12 26.00.01.491
A-2094654 AISC 360-16/22: Incorrect default SNUG value for built-up members  1 - Critical 21.00.02.30 26.00.01.491
A-2106652 CSA S16-09/14: Limiting value of Factored Moment Resistance (Mr) as per Clause 13.6(a)(i)  1 - Critical 20.07.10.41 26.00.01.491
A-2009553 Wind Load assignment Combining RANGE and LIST methods  2 - High 20.07.04.12 26.00.01.491
A-2016637 AISC ASD: Incorrect Section Modulus used in design of multiple angle profiles  1 - Critical 20.07.08.22 26.00.01.491
A-2017394 Local deflection checks of models distant from the global origin  2 - High 20.07.04.12 26.00.01.491
A-2024531 Incorrect open-structure wind loading for angle profiles  1 - Critical 20.07.04.12 26.00.01.491
A-2092167 Incorrect processing of floor load within a reference load case  1 - Critical 20.07.08.20 26.00.01.491
A-2011909 EN1993-1-1-2005: Section classification check is skipped  2 - High 20.07.06.23 26.00.01.491
A-2125826 IS 1893 (Part 1) 2016: Incorrect static base shear used for comparison with response spectrum base shear  2 - High 21.03.00.146 26.00.01.491
