| | Product: | MicroStation | |
| | Version: | 08.11.xx.xxx, 10.xx.xx.xxx | |
| | Environment: | N\A | |
| | Area: | Dimensions | |
| | Subarea: | Dim Styles | |
Is there a way to compare and see the differences between two dimension styles?
- Under the Advanced tab of the Dimension Styles, change the mode to Comparison or Differences.
- Select the two dimension styles from the tree.
- Holding the CTRL-button down while selecting the dimension styles will allow dimensions to be selected that are not sequential.
Other language sources
| | Original Author: | Bentley Technical Support Group | |
