RCDC General
Product(s):
STAAD Advanced Concrete Design
Version(s):
Connect Edition
Environment:
Area:
Concrete Design
Subarea:
General
Original Author:
Ranjana, Bentley Technical Support Group
[[Importing gridlines from AutoCAD.]]
[[Design calculation reports can be exported in Excel format.]]
[[Settings to freeze drawing style.]]
[[Unable to read analysis data]]
[[Load Combinations considered for regular and irregular buildings]]
[[Data exported from Etabs in FPS(foot-pound-second) reflects in RCDC as MKS(meter-kilogram-second).]]
[[Is the Vertical axis of STAAD and RCDC Same.]]
[[How to change safety factor for design codes in RCDC?]]
[[Defining concrete grade as 27 N/sqmm in RCDC for IS code design.]]
[[To design a building for repeat load cases from STAAD in RCDC.]]
[[Explanation of live load reduction as per Table-10 of IS 1893-2016 in RCDC.]]
[[RCDC unable to read load combinations if added in analysis file .]]
[[Ductile detailing of beams columns without increasing cross section.]]
[[Shear calculations in RCDC is limited to 415 N/sqmm]]
[[RCDC create "Text Schedule" with unrecognizable characters.]]
[[Unable to read Staad files as RCDC closes on its own.]]
[[Style Manager setting in RCDC .]]
[[Steps to add new grid lines in RCDC]]
[[Importing same grid data, column/beam marking and sizes in all design modules in RCDC for a structure.]]
[[Force considerations from different Analysis software like STAAD to RCDC, ETABS to RCDC and RAM-SS to RCDC.]]
[[Unable read file if steel and concrete columns are at support level]]
[[Error while opening Rcdx file older than Version 10.]]
[[Ignore Beams/Columns during Model import in RCDC]]
[[How to export Load combination and Load cases in RCDC ]]
[[Complete Wall geometry is not identified when we import ETABS (.accdb file) in RCDC]]
[[Crack width calculated by RCDC appears to be in negative value. ]]
[[Display of English and Metric units in RCDC.]]
[[Advanced Concrete Design Not Found ]]
[[Using Discussion Group within STAAD RCDC]]
[[File Compatibility in Different Versions]]
[[Water Tank Structure Design mode in RCDC]]
[[Design Method for ACI Code]]
