| Version: | 08.11.09.XXX, 10.XX.XX.XX | ||
| Area: | UI Customization | ||
| Subarea: | Menus |
Preferences Dialog without "OK" button.
In the Preferences Dialog the buttons "OK", "Cancel" and "Default" is missing.
Rename upf and -restoredefaults don't solve the problem
Change Screen Solution
Screen solution was set to 1024 * 786.
Changing it to 1280 * 1024 solved the problem
| Original Author: | Jutta Eisenhauer |
