| Version: | 08.11.09.XXX, 10.XX.XX.XX | ||
| Area: | DWG | ||
| Subarea: | Save |
Graphic group not retained in DWG files.
After saving DWG file or saving as DWG, graphic groups are removed.
Enable "Preserve MicroStation Settings" in DWG Open Options.
Steps:
1. In MicroStation "File Open" window, highlight the DWG file, select "Options".
2. In the "Basic section", enable "Preserve MicroStation settings.
3. Click OK and open the file as needed.
