Is Package Cache needed?
  Product(s): MicroStation
  Version(s): 10.00.00.25
  Environment: N\A
  Area: Installation
  Subarea: General
After installing MicroStation CONNECT Edition a folder Package Cache gets created under C:\ProgramData\Package Cache
The recommendation from Microsoft is to not to delete this folder. It is also not recommended to move it to another location either.
Some explanatory information from Microsoft can be found here.
See also
How to change the location of installation files using Package Cache
Other language sources
  Original Author: Andrea Figurova
