| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 10 December 2012 |
| Date modified | 10 December 2012 |
One of the particular features of PLAXIS is the use of interfaces for modelling soil-structure interaction. This document describes an example that has been used to verify the performance of these elements by means of a sliding block.
Used versions for documents:
