| Version: | 08.11.09.XXX, 10.XX.XX.XXX | ||
| Area: | View | ||
| Subarea: | Clip Volumes |
When a clip volume is created attempting to manipulate the cut plane results in the cut plane snapping to clip volume of minimal thickness. This is demonstrated in the attached video.
This occurs if AccuDraw is turned off. Turn AccuDraw back on to take control during manipulation.
