Applies To | |||
Product(s): | MicroStation V8i | ||
Version(s): | 08.11.XX.XX | ||
Environment: | N/A | ||
Area: | Programming | ||
Subarea: | General | ||
Original Author: | Bentley Technical Support Group | ||
Where to find information regarding developing with MicroStation (in the order each should be referenced):
MicroStation SDK ReadMe ..\Bentley\MicroStation\readme_microstationsdk.chm
The ReadMe contains the following information pertaining to the MicroStation SDK:
MicroStation Programming Interfaces Reference ..\Bentley\Documentation\MicroStationAPI.chm
This reference covers various topics, including (but not limited to):
Event Handling | The recommended method to interact with MicroStation V8's View, AccuDraw, and Mouse control systems |
XAttributes | Extended information that is stored 'on' an element |
Viewports | The abstraction of a visible information container |
Transaction Manager | Journals all transactionable (or undoable) changes to Persistent Elements during a session |
Font Manager | The root for all font access |
MstnTool | The MstnTool class encapsulates the MDL "state" functions and helps simplify the process of writing tools for MicroStation. |
ElemHandles | An indirect reference to an element's current state |
Geographic Coordinate Systems | |
Scoped Variable Management | Scope management classes use C++ constructor and destructor calls at scope entry and exit time to guarantee corresponding setup and teardown operations. |
NOTE: When developing in C++ using the MicroStation API, the first Bentley include file in your source should be MicroStationAPI.h
. This will ensure that some necessary header files are included in the order they need to be.
MDL API Function Reference ..\Bentley\Documentation\MDLAPIFunctionReference.chm
This document identifies the MicroStation API published functions, categorized by various subsystems and topics, and includes:
All functions in the MDL API Function Reference are automatically tagged with the xx.yy.zz
build in which they were initially included as public functions. Some things to consider regarding this include:
Refer to the delivered deprecated*.fdf
files in ..\mdl\include\
for the latest deprecated MDL functions. Bentley highly recommends avoiding the use of deprecated functions.
To search for functions that appeared in a particular version of MicroStation, click on the Search tab and use the following as examples:
MDL Programmer Guide ..\Bentley\Documentation\MDLProgrammerGuide.chm
MDL lets developers create professional-quality applications that integrate seamlessly with MicroStation and Bentley products. It is the recommended way to access MicroStation V8 DGN files with full fidelity. MDL facilitates development of applications by providing consistent functionality and capabilities across the products on which they run. It can be used to develop simple utilities, customized commands or sophisticated commercial applications for vertical markets and is used by Bentley's developers as the tool to incorporate modular functionality into its products. MicroStation V8 can also host and interface with a variety of programs and applications written in C, C++, C#, and Visual Basic. The MDL Programmer Guide includes, among other things:
MicroStation VBA documentation ..\Bentley\MicroStation\MicroStationVBA.chm
This document is delivered with MicroStation. MicroStation VBA, the MicroStation V8 implementation of the Microsoft Visual Basic for Applications engine, one of the most popular programming environments in the world, provides MicroStation users (as well as developers) with a large number of capabilities -- from easy customization to tight integration with other Windows applications. In addition to identifying all the enums, objects, events, methods, properties, and types available, the MicroStation VBA documentation also includes a number of examples as well as a general overview covering the following:
MicroStation BASIC documentation ..\Bentley\Documentation\basic_help.chm
Delivered with MicroStation and covers the entire functionality of MicroStation BASIC. Note that MicroStation BASIC has not been enhanced and will be unsupported in future versions. Bentley highly recommends migrating existing MicroStation BASIC code to Visual Basic or Visual Basic for Applications.
Example Code
There are a number of VBA and MDL code examples delivered with MicroStation, the MicroStation SDK, and included with the documentation for both (check the QuickInstall Guide for the default installation location of examples delivered with the MicroStation SDK). Additional example code is also available at the following locations:
The Bentley Developer Network provides you with resources to help successfully develop and test software products that complement Bentley technologies. Whether you are a new or an experienced developer, you have convenient access to information, tools, technical support and programming resources to help you work more efficiently. And that means you will reduce development costs and time to market. The Bentley Developer Network program delivers essential programming information and the latest Bentley software along with the tools you need to extend that software. Click here to find out what Bentley Developer Network membership level is right for you.
