| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 30 June 2016 |
| Date modified | 30 June 2016 |
This document verifies that groundwater flow principles are correctly implemented in PLAXIS. Assuming a horizontal confined aquifer, the radial flow towards a well is studied under transient and steady-state flow conditions. PLAXIS results are compared with the analytical solutions presented by Theis (1935) and Thiem (1906).
Used version:
This requires a PlaxFlow module for groundwater flow
