| Application | PLAXIS 3D |
| Version | PLAXIS 3D |
| Date created | 03 December 2012 |
| Date modified | 03 December 2012 |
This document describes an example that has been used to verify the bearing capacity of the ground anchors in PLAXIS 3D. The test is performed with a ground anchor in loose sand as well as in dense sand. The skin friction along the grout body is considered to be either constant or linear for both soil material models.
Used version:
