| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 17 December 2012 |
| Date modified | 17 December 2012 |
In this test the natural frequency of a simply supported beam will be determined and compared with the analytical solution. The natural frequency of a system is the frequency that characterises the response of the system in a free vibration condition. The problem is validated in PLAXIS 2D and PLAXIS 3D.
Used version:
This requires the Dynamics module.
