| Application | PLAXIS 2D |
| Version | PLAXIS 2D |
| Date created | 13 November 2012 |
| Date modified | 13 November 2012 |
This case describes an example that has been used to verify that stresses are calculated correctly during the expansion of a cylindrical cavity in an elastic perfectly-plastic cohesive soil (see below). Both small and large displacement calculations are performed.
Used version:
