| | Product: | MicroStation | |
| | Version: | V8i, CONNECT | |
| | Environment: | N\A | |
| | Area: | Text | |
| | Subarea: | Fonts | |
We have received some font and linestyle RSC files from another company. What do we do to enable MicroStation to find these RSC files?
- Go to Workspace > Configuration to open the Configuration dialog box and select the Symbology category.
- Select the Font Directories variable and click Edit to open the Edit Configuration Variable dialog box.
- Set the Edit mode to Append, and enter the full path to the folder that contains the font RSC file in the New Value field, and click OK.
- In the Configuration dialog box, select the Symbology Resources and click Edit to open the Edit Configuration Variable dialog box.
- Set the Edit mode to Append and enter in the full path, including the actual file name, in the New Value field. You can also use *.RSC in place of the file name and this enables MicroStation to choose all files with an RSC file extension in that directory. Click OK.
- Click OK in the Configuration dialog box, then Yes to save changes.
- Close and restart MicroStation. The new settings are now in effect.
See also
Other languages sources
Français
| | Original Author: | Elisa Pry | |
