| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 20 December 2012 |
| Date modified | 20 December 2012 |
In this validation surface, waves on an elastic half space are considered. In this case, the surface waves are generated by a prescribed displacement that is activated harmonically. A comparison is made between the results from the PLAXIS dynamic module and results obtained by Chouw, Le & Schmid (1991) using boundary elements.
Used version:
This requires a Dynamics module
