| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 02 January 2013 |
| Date modified | 02 January 2013 |
This document describes an example that has been used to verify the dynamic response of a multi layer system due to a transient load pulse. For such a system, no analytical solution exists. For verification, the computational results of PLAXIS are compared with those obtained from a semi-analytical technique using the 'spectral element method' (Al-Khoury, Scarpas, Kasbergen & Blauwendraad, 2001).
Used version:
This requires a dynamics module
