| Version(s): | 10.15.02.11 | ||
| Area: | FAQ | ||
| Subarea: | N\A |
The MicroStation CONNECT Edition Team examined and resolved many issues across multiple areas for MicroStation CONNECT Edition Update 15.2.
| Number | Description |
| 1113932 | Improved performance when unrasterized print in MicroStation Connect Edition takes extended time when WMS is attached to a reference file |
| 1061562 | Resolved issue with error has occurred when saving specific dgn to dwg. |
| 1111914 | Resolved issue with Mtext wrapping issue that resulted in (%%D) displayed incorrectly |
| 1116011 | Fixed issue when text clears from a cell that results in the entire cell graphics disappear in specific file |
| 1119957 | Resolved issue with Chinese tag text are changed after modification |
| 1122452 | Fixed issue with specific DWG pattern not displayed when opened. |
| 1102964 | Fixed issue with Leader arrowheads disappearing from specific file. |
| 1121958 | Fixed issue with redefining file name is not refresh in all referenced model in specific file |
| 1108696 | Resolved issue with specific file exits when attaching specific reference files |
| 1120008 | Fixed issue with Is Array turns True after upgrading Tag Sets |
| 1068493 | Fixed issue with specific MicroStation crash with specific signed MVBA |
| 1077875 | Resolved issue with specifit tags disappearing when you edit tags in specific file |
| 1095465 | Resolved issue with Tags do not display after edit tags in specific files. |
| 1114924 | Resolved issue with restore "total" row in Reports' aggregates and sums |
| 1114726 | Fixed issue with Windows Explorer not showing DGN preview. |
| 1114775 | Fixed crash when on opening DGNLIB which is assigned to MS_DGNLIBLIST_ITEMTYPES |
| 1108734 | Resolved issue with Annotation scale in Layout (Sheet) not applied in DWG Workmode |
| 1108872 | Fixed issue with Wipeout of Reference data ignored in DWG workmode |
| 1114463 | Fixed issue with underscore at beginning of Level name not displaying in Attributes tool group |
| 1021257 | Resolved issue with opening specific file causes crash |
| 1110797 |
Resolved issue with specific file that could not package single i.dgn file |
| 1108624 |
Added support for sketchup 2020 format |
