| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 07 January 2013 |
| Date modified | 07 January 2013 |
This document describes an example that has been used to verify that the dynamic response of a footing is correctly calculated in PLAXIS. For that purpose the response of a rigid circular footing subjected to a vertical harmonic load is studied.
Used version:
This requires a Dynamics module
