| Version(s): | 10.10.00.23 | ||
| Area: | Exception | ||
| Subarea: | N\A |
A dump file is a snapshot of an application at the point in time the dump is taken.
For performance or hang issues, you need to collect, hang dumps. A hang dump is also known as "manual dump".
Download ProcDump from this link
Download the complete SysInternals-Suite from this link Or use the Sysinternals Live - https://live.sysinternals.com/
1. Open Command Prompt
Press Win + R keys and key in Cmd
2. Assuming MicroStation is in a hung state
Key-in "procdump microstation.exe"
Key-in "\\live.sysinternals.com\tools\procdump microstation.exe"
To create a dump file in folder "d:\dumpfolder\"
Key-in "procdump microstation.exe d:\dumpfolder\"
Key-in "\\live.sysinternals.com\tools\procdump microstation.exe d:\dumpfolder\"
Write 3 mini dumps 30 seconds apart of a process named 'microstation':
Key-in "procdump -s 30 -n 3 microstation.exe"
Key-in "\\live.sysinternals.com\tools\procdump -s 30 -n 3 microstation.exe"
3. Check this link for more examples
Note: For MicroStation V8i, use process name as "ustation.exe" e.g. "procdump ustation.exe"
