| Version: | V8, XM, V8i, CONNECT | ||
| Area: | Groups | ||
| Subarea: | General |
What is the difference between a Quickset and a DisplaySet?
A Quickset is intended to provide control over the manner in which a group of elements are selected and manipulated, and is essentially an abbreviated method of creating a Named Group. The name itself is strictly based on the Quickset number chosen via Shift-Right Click > Quickset Save.
A Displayset, on the other hand, controls how a group of elements is displayed on-screen. When a Displayset is active, all elements not belonging to that Displayset will not be visible.
Note that a Quickset can be added to a Displayset, thereby providing a mix of these two distinct functions. After creating a Quickset choose Utilities > Named Groups, and in the Named Groups dialog highlight the Quickset that was created. Either click on the "Put Elements into the Displayset " icon, or right-click and choose the "Add to Displayset option".
