| Issue Number | Description |
| 369501 | Resolved issue with AutoCAD plot style table (stb) is not resymbolizing shared cells properly. |
| 564791 | Fixed output to PDF missing lines when printing in rasterized mode in specific file. |
| 635473 | Resolved issue with thematic height not working with specific files, colors are not visible. |
| 918714 | Fixed issue with incorrect non-rectangular clipping by QV results in filled shapes not being plotted correctly for Bentley printer drivers that do not support driver clipping. |
| 928799 | Fixed create Display Set in Level Display Dialog not working. |
| 947966 | Text in Dimensions not displaying line weight correctly in specific file. |
| 976776 | fixed issue with PDF attached to DWG with Transparent switch off is turned on when saving specific file. |
| 980995 | Deleting text contents contained in a specific cell. |
| 988904 | Improved the time to opening files during an In-Use DGN file. |
| 1004468 | Level Overides is not set/cloned to saved view to Drawing model to sheet. |
| 1017920 | Fixed isue with Select by Attributes (Text) not working. |
| 1059525 | Fixed Point Curve changes to B-Spline with break or trim tool |
| 1059538 | Fixed Fence From Flood on Shape used as a Reference Clip Boundary disappears if Shape Deleted. |
| 1066975 | Attributes level list sort differently in specific file. |
| 1074948 | Dropped parametric cells become bigger when Working Units are different |
| 1077135 | Fixed issue with specific file that locks up when trying to print a .dgn with an element fence. |
| 1077744 | Improved performance with Large PickList |
| 1079487 | Dropping cells with parametric solids, in design file with different Working Units as the original cell was created in. |
| 1086923 | Keyin "Calculator <expression>" raises exception, if return value of <expression> is a pointer. |
| 1089669 | Resolved crash while filling enter data field for below mentioned scenario |
| 1090238 | Resolved issue where Place Fraction Symbol from Symbol Inserter, gives you a Question Mark instead of Fraction selected. |
| 1093862 | Fixed issue with Create Region tool doesn't work in specific file. |
| 1094252 | Fixed specific issue with 'Save as' Remap does not remap with ByLevel. |
| 1095538 | One custom tool icon is missing in specific dgnlib. |
| 1099807 | Fixed issue with Raster boundary not being used to Create Region in specific file. |
| 1100396 | Explorer dialog box showing the wrong translation of Items |
| 1100527 | Resolved issue with error when using Item Types with a Lookup expression from Excel File column having Date formatting. |
| 1100593 | Export V8 DGN to support Dynamic Visible Edge Reference merging in particular file. |
| 1101768 | Cell not merging as defined by table seed in specific file. |
| 1102247 | Fixed issue with Level Overides is not set/cloned to saved view to Drawing model to sheet. |
| 1102248 | Fixed issue with turning off construction elements in the plan sheets. |
| 1104156 | Resolved issue with Mirrored Parametric Solid not visible in cached Reference attachment. |
| 1104819 | Fixed issue with Parametric Array tool doesn't work with nested parametric cells |
| 1104851 | Counterbore and Countersink type Holes are created incorrectly when Last Face is not Parallel to the First Face where they are placed |
| 1105292 | Fixed issue with RQ command fails when "Auto-focus Tools Settings" is turned on |
| 1106345 | Resolved error: Unable to convert to solid of mesh created in OpenRoads |
| 1108232 | Fixed issue with level manager opens showing the levels of the master file instead of levels used in the reference highlighted. |
| 1108469 | Resolved issue with Parametric Cell: Switching between Parameteric Cell and a dgn to place the cell crashes |
| 1108740 | Resolved issue with Tube Feature (Extrusion Along Path : Circular Profile) doesn't keep up with its Path Element. |
| 1108761 | Resolved issue with Tube Feature (Extrusion Along Path : Circular Profile) Solid generation Fails if Path Origin is located at Corner. |
| 1108805 | Fixed issue with error - qvision [qvi_beginPaintCapture]: Error 18 |
| 1109187 | Fixed issue with Localized help file is not accessible directly from MicroStation when using F1 key in offline mode. |
| 1109590 | Resolved issue with Named Group containing Referenced elements when attached into Sheet Model Reference attachment is missing. |
| 1110147 | importing MC30U_01.ifc file in V8i SS10 or CONNECT update 14.2 the display is different in comparison with BIM Vision for IFC |
| 1110555 | Shared cell color did not retain from dgn to DWG. |
| 1110575 | Resolved issue with opening file in MicroStation CONNECT causes crash in specific file. |
| 1110692 | Fixed issue with publishing specific iModel. |
| 1111259 | Resolved issue with DGN Reprojection to Nested Reference fails. |
| 1111474 | Convert of E57 Point Cloud Not Displaying Relevant Error Message On Failure |
| 1111920 | Resolved issue with issues with Ratio of leader line and Multi_Leader annotation scale . |
| 1112249 | Resolved issue with PDF raster attachment comes in at wrong scale when opening DWG file. |
| 1113400 | Resolved issue with UPF related product crash and performance issues. |
| 1114460 | Resolved issue with hang for WMTS User Server URL with specific file. |
| 1114462 | WMTS User Server URL opens browser. |
| 1114654 | Text Node Not Placed As Singular Color And Being Located With Select Element Tool Choosing White. |
| 1114935 | Background Map does not display correctly. |
| 1115263 | Failed to import excel if it's exported from model having same Master unit and Sub unit. |
| 1115567 | Resolved issue with background map is appearing on top for attached dgn for GCS RI83F. |
| 1115982 | Resolved issue with Failing to Import Variations from Exported CSV file(the exported model having same MU and SU). |
| 1116131 | Resolved issue with specific file crash after copy paste Raster using clip board. |
| 1116229 | Fixed issue with mirrored Smartsolid cell displays incorrectly. |
| 1119166 | Resolved issue with Coordinate Shift with MS/J seed files being opened from IPLOT |
| 1119403 | Modifying Parametric Solid Loses Symbology & Variables Defined on it. |
| 1119668 | Resolved issue with Grouped Hole filled elements cause lag in MicroStation CONNECT Edition. |
| 1119959 | When saving a DGN file with Embedded image to DWG, The embedded image gets rotate, on top of vector elements and scaled up. Opening the DWG created with Microstation in Autocad image is invisible. |
| 1119974 | Stacked fraction created by double spacing causes appearance of "?" and created by "ISF" changes the weight of the text. |
| 1120333 | Resolved issue with maintain stacked fraction in tags placed in specific file. |
| 1120355 | Resolved issue with Bing map does not work via system proxy setting. |
| 1120412 | Added back non AVX processor installer code. |
| 1120533 | Resolved issue with "jpg was not found". Materials saved on the network are not found when using relative path. |
| 1121786 | Resolved issue with Complex Line String displays differently in specific file. |
| 1121924 | Resolved issue with MicroStation crashes when attaching specific reference files. |
| 1122057 | Resolved issue with MicroStation crashed while using copy parallel tool in specific file. |
| 1122423 | Resolved issue with Merge Name checked on, unable to turn on/off Levels from Reference attachment in Level Manager. |
| 1122455 | DWG file containing polyline composed of Lines/Arcs with 'Run Through Corners' not displaying/printed correctly in MicroStation |
| 1122492 | Stencil tool issues with tolarence, not get stenciled out of view lines |
| 1122545 | Resolved issue with Phantom Levels & elements in the file after deleting all elements specific file. |
| 1122776 | Level display change from nested reference not shown in master file in specific file. |
| 1123579 | ‘Suppress clashes between elements’ option from Clash Detection settings is not working. |
| 1124452 | Resolved issue with Save raster produces low quality ECW. |
| 1125234 | Cloud by point from Annotation tab\Detailing symbols throws unknown key-in or command. Same issue accessing cloud by point from Collaborate tab. |
| 1125480 | Resolved issue with Cloud by elements from Annotation tab\Detailing symbols throws unknown key-in or command. |
| 1125496 | Resolved issue with unable to display the half width Japanese characters in Properties dialog box. |
| 1126073 | Resolved issue with use "%" in item expression. |
| 1126546 | Resolved issue with properties are missing when we Publish as i.dgn. |
| 1126738 | Resolved issue with jp2 image is not displayed properly in specific file. |
| 1128954 | Resolved issue with specific JP2 image attached in incorrect location. |
| 1129521 | Improved performance when It takes longer time as selection of multiple sheetlinks increases in Sheet Index. |
| 1129627 | Improved performance of Folder creation in Sheet Index |
| 1129711 | Resolved issue with Measure Distance "Minimum Between" does not work on 3D elements in specific file. |
