Maximum value bulk modulus water not correct (relevant for undrained, consolidation and flow calcula
ApplicationPLAXIS 2D
PLAXIS 3D
Issue status✔ Solved
First Affected VersionPLAXIS 2D 2010.01
PLAXIS 3D 2010.01
Found in VersionPLAXIS 2D 2010.01
PLAXIS 3D 2010.01
Fixed and Released in VersionSolved in a recent version
Issue #17989
Date created22 May 2013
Date modified24 October 2016
Problem description
In the indicated Plaxis versions some issues exists with the calculation of the maximum value used for the bulk modulus of water. This issue is only relevant for Undrained (A or B), Consolidation and/or Transient flow calculations and only when using stiffer (sand or rock like) materials. In general the effects will be small for these situations.
The following is happening: with an Undrained (A or B), consolidation or transient flow analysis the program calculates a bulk modulus for the water (Kw) based on the Input value of the effective soil stiffness (K’). The program by default uses a large ratio between Kw and K’ such that the Plaxis calculation obtains realistic behaviour, but not such that the Plaxis calculation has numerical problems.
However, to prevent that the program may use unrealistic large values for Kw (if already a high K’ is entered) the value for Kw is limited to the actual value of the water bulk modulus (= 2E6 kPa) called Kw,max.
The following issues now exist:
In the first case this issue might cause too low excess pore pressure to be generated, a too slow consolidation process or might result in incorrect discharges in a transient groundwater flow calculation. In the second case the issue might cause too high excess pore pressures to be generated, a too fast consolidation process or result in incorrect discharges in a transient flow calculation.
This issue is solved in PLAXIS 2D 2012.00, however note the related issue with unit conversion which still exists in this version.
This issue is also solved for PLAXIS 3D: since 3D2013.00
