| Version(s): | 08.11.09.000, 10.xx.xx.xxx | ||
| Area: | Configuration | ||
| Subarea: | General | ||
| Original Author: | Bentley Technical Support | ||
MS_LEGACYDRAWORDER and V8i or CONNECT
The configuration variable "MS_LEGACYDRAWORDER" from XM no longer
functions in V8i or CONNECT.
The variable has been replaced with an option for the Wireframe Display
Style(Settings>Display Styles) called "Use File Order for Display". This
way you can give the file to someone else and it will always look the
same.
