| | Product: | MicroStation | |
| | Version: | CONNECT | |
| | Environment: | N\A | |
| | Area: | Printing | |
| | Subarea: | Driver/PDF | |
How to upgrade MicroStation or any other print engine on the ICS for PDF server machine?
Steps to be followed-
- Take backup of the custom fonts and resources present in the locations- C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\Fonts and C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\Symb
- Make sure no jobs are running inside Bentley Automation Service Administrator inside the iCS Server machine
- Stop ProjectWise Orchestration Framework service
- Kill any iplotorg.exe and Microstation.exe/ustation.exe process in Task manager (Details tab)
- Remove current MicroStation
- Reboot machine
- Install new MicroStation
- Integrate MicroStation with ProjectWise by repairing ProjectWise Explorer
- If you have custom fonts or resources, you need to restore them to MS_FONTPATH & MS_SYMBRSRC variable paths (see first point)
- Open ProjectWise InterPlot Organizer Configure utility and check- MicroStation integration is toggled ON and used as IPLOT engine
- Start ProjectWise Orchestration Framework service
If you are upgrading OpenBuildings Designer, please verify which dataset is being used. A wrong dataset can lead to rendition errors.
See also
Other language sources
| | Original Author: | Sukalyan Senapati | |
