How to create a list of all CONNECT Edition Configuration Variables
 Product:MicroStation
 Version:10.00.00.25
 Environment:N\A
 Area:Configuration
 Subarea:General
This article describes how to create a list of all configuration variables using MicroStation CONNECT Edition.
Recommendations
Option 1
Tab: File > Settings > Configuration > Configuration Variables > File > Print Variable information
Option 2
Tab: Home > Primary > More Arrow > Key-in > enter following key-in followed by the Enter key: mdl load cfgvars printCfgVarResource
Both options, will create two text files named cfgvars.txt and cfglong.txt in the directory where variable MS_SCR points to.
MS_SCR - Directory for scratch files.
This text file also displays the hidden system variables such as "_USTN" which are not displayed in the configuration dialog by default.
Product TechNotes and FAQs
Other Language Sources
Deutsch
Español
Français
 Original Author:Yvonne Lohse
