| Version: | 08.11.09.357 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces |
Default back to configured seed file.
When creating a new design file, the system should not use the seed file that was selected the in a previous path, but should default back to the configured seed file.
Set and lock MS_SEEDFILES and MS_DESIGNSEED
The example configuration file below shows how to set and lock these variables:
Standard seed file is located in the shown path on a server.
Servername: CSSERVER
Path: \standards\compseed\
Filename: csseed.dgn
# The variable below specifies the path where MicroStation should search for seed files
# If you have a mapped drive and a drive letter,
# that can be used instead of the UNC naming shown here.
# Note that in a path specification in a configuration file,
# you should always use forward slashes instead of back slashes
# and always end with a forward slash
# The line with the %lock tells MicroStation to only use that variable definition,
# so in this case not use the last used path as found in the user preferences file (.upf)
MS_SEEDFILES = //CSSERVER/standards/compseed/
%lock MS_SEEDFILES
# The variable MS_DESIGNSEED specifies the name of the seed file
# that MicroStation should use
# so in this case the name of the seed file
MS_DESIGNSEED = csseed.dgn
%lock MS_DESIGNSEED
# Make sure to end with a blank line in your configuration files.
