| Version: | V8i, CONNECT | ||
| Area: | Text | ||
| Subarea: | Fields |
I have a file that contains text fields displaying the area of elements and the length of elements. Is it possible to change or drop these fields to regular text?
There are a couple of options available to convert the text in a text field into plain text.
The first would be to cut+paste the text field.
An option has been included with the Drop Element tool called Complex.
When this option is selected you should be able to drop a single or multiple text fields to plain text.
The grey background of the field should disappear when the text has been dropped.
Help Documentation - Drop Element
| Original Author: | Andrew Bell |
