| Version(s): | 10.16.00.80 | ||
| Area: | Text | ||
| Subarea: | Fonts |
Some Arabic text characters are missing in Connect
User is using RSC font AGUIDE and some Arabic characters are missing in Connect. Display in V8i is correct.
Steps to follow to fix this issue
1. Set System Locale to English (United States)
2. Open any text editor “e.g. Notepad++” as Administrator
3. Open file “MstnFontConfig.xml” from the following location
C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\Fonts\
4. Search for following lines
<RscFontInfo>
<Name>*</Name>
5. Add these lines before the above
<RscFontInfo>
<Name>Aguide</Name>
<Hidden>False</Hidden>
<CodePage>1256</CodePage>
<CreateShxUnifont>True</CreateShxUnifont>
</RscFontInfo>
6. Sample is attached for reference which you can copy to folder
communities.bentley.com/.../3060.MstnFontConfig.zip
7. Re-open MicroStation Connect and check the Arabic character display for AGUIDE font.
Arabic characters overlap in View display
Arabic Text Displays Backwards
| Original Author: | Leonard Jones |
