MicroStation exits when attaching Bing Map
 Product(s):MicroStation
 Version(s):10.16.00.80
 Environment:N\A
 Area:Raster
 Subarea:Bing Maps
MicroStation exits when attaching Bing Map.
User is connecting to internet via a Proxy environment
Proxy was set to "Use System Proxy Settings" in Bentley Licensing Tool
Changed to "Use Custom Proxy Settings" and Bing Map attach works.
• Open Bentley Licensing Tool
• Go to Tools > Options
• Set Use Custom Proxy Settings
• Enter Proxy Server/Port details ProxyIP:PortNo
• Enter Proxy Server Authentication if applicable
• Test Proxy Configuration
• Click Apply, OK button to save the settings
Bing Maps
Other language sources
 Original Author:Leonard Jones
