| Version: | CONNECT | ||
| Area: | View | ||
| Subarea: | General |
When I open a dgn file, the design file opens with the view rotated at 180 degrees. The file is flipped over. Every design file I open, behaves this way. How can I resolve it?
You can "Restore MicroStation to Factory Defaults", here is a wiki document that will help to walk you through the required steps:
Restore MicroStation to Factory defaults
| Original Author: | Judy Wong |
