| Version(s): | 08.05.02.35; V8i (+Select Series), CONNECT Edition | ||
| Area: | Drawing Aids | ||
| Subarea: | AccuDraw | ||
How to stop AccuDraw compass from relocating to the element being manipulated.
Disable "Floating Origin".
Steps:
1. From Menubar, go to Settings > AccuDraw [AccuDraw Settings dialog opens].
2. In AccuDraw Settings dialog, switch to Operation tab.
3. Disable "Floating Origin".
4. Close and go File > Save Settings.
In MicroStation CONNECT Edition you can find this setting via File > Settings > User > AccuDraw Settings
AccuDraw Compass is not showing
