| Version: | V8 | ||
| Area: | Text | ||
| Subarea: | Fields |
How to get underscore working either as data field or as an underscore in the same model.
If you go to Workspace > Preferences > Text > ED Character and change that to any character you are not going to use (for example a Q character).
Then enter the text you wish.
And if we then change the ED Character back to underscore, the underscores we entered when the ED Char was still Q remain as underscores. If we would have entered a Q during the time when it was the ED Char, this would display as the character currently set as ED Char when Data Field display is on.
How to create a Data Field in MicroStation v8
| Original Author: | Sami Rautiainen |
