MicroStation v8i will not read configuration variable pathway that contains double space
 Product:MicroStation
 Version:v8i, CONNECT
 Environment:Windows 10
 Area:Configuration
 Subarea:General
While in a MicroStation v8i configuration file (UCF, PCF, CFG, etc.), I am attempting to define a configuration variable to point to a file or pathway that contains a double space.
For instance, in the below untitled.ucf file, the MS_BACKUP defined pathway contains a double space.
Upon looking at the workspace configuration variable summary (Workspace>Configuration), the defined pathway has reverted back to a single space which does not read the actual pathway properly.
This issue only occurs in MicroStation v8i.
Upgrading product versions to MicroStation CONNECT Edition will resolve the issue and allow MicroStation to read double spaces within configuration variable definitions.
Design file contains spaces in either the path or file name
Other language sources
 Original Author:Jayson Perry
