| Version: | V8i, CONNECT | ||
| Area: | Interchange | ||
| Subarea: | IFC |
How can I convert DGN to IFC
MicroStation V8i - MicroStation 2024:
MicroStation V8i through MicroStation 2024 cannot export or "save as" to IFC file format.
MicroStation can only view/open IFC files.
However, MicroStation is already being more helpful by allowing IFC import through referencing.
You will need OpenBuildings Designer (previously AECOSim Building Designer) to perform this.
Further information about OpenBuildings Designer can be found here:
https://www.bentley.com/en/products/brands/openbuildings
MicroStation Connect 2025:
With MicroStation 2025 a new Techn preview has been added.
Note: Take advantage of this Technology Preview, a non-public software service and/or application for evaluation purposes only. Please use the Technology Preview in your normal business environment as needed to form an opinion concerning the performance of the Technology Preview. Bentley personnel would welcome your valued feedback concerning the performance of the Technology Preview as you evaluate the capabilities. Please be aware that at some point, you may receive notice from Bentley that such use must cease or this Technology Preview will become unavailable to you. As we receive feedback, this Technology Preview may also be enhanced, updated or also discontinued without notice. As a Technology Preview, it is provided to you "as-is" without the benefit of any Bentley warranty, indemnity or support obligation.
New and Changed in MicroStation 2025
| Original Author: | Judy Wong |
