| Number | Description |
| 656142 | Resolved issue with specific file where clipped raster is not displaying |
| 656212 | Fixed issue with the display of specific attached files in Raster Manager disappearing when reopening the file. |
| 658992 | Fixed issue with Workspace configuration not loaded when changing workspace during session |
| 660159 | Resolved issue with parsing from unique WMS server. |
| 660178 | Improved performance with Raster Manager and Bing Maps. |
| 659885 | Fixed an issue with WMTS map editor is giving an error when trying to connect to a specific User Server url. |
| 659894 | Corrected WMS display issue on unique user dataset. |
| 659530 | Resolved issue with specific case where user was not able to attach bing map. |
| 659543 | Fixed WMS Server, error parsing capabilities response. |
| 661623 | Improved performance loading of ECW images. |
| 661686 | Resolved Slow Raster Manager ECW attachment in specific file. |
| 661566 | Resolved error in specific case where Bing Maps Background Unavailable - 7060 Error |
| 668721 | Resolved issue with Background Map crash when user uses "Use System Proxy Settings". |
| 670335 | Fixed issue with specific file where they are not able to load DGN with WMS |
| 659354 | Resolved issue with a Recorded Bentley Macro Recorder crashing on specific macro editing or trying to execute. |
| 658724 | Resolved issue with Macros Dialog not listing password protected VBA projects. |
| 655775 | Resolved issue with VBA TextNode property LineSpacing returns a value scaled with UOR instead of working units |
| 654988 | Fixed issue with the VBA method fence.GetContents() does no longer provide correct results for Curves and BSpline Curves |
| 654350 | Resolved issue with VBA property Element.ModelReference.Name returns incorrect string if file opened with OpenDesignFileForProgram |
| 654540 | Resolved issue with VBA method CreateCellElement2 to place a cell from library omits ItemType properties attached to cell model |
| 654275 | Fixed issue with MS_MACRONEWFILEDIRECTORY is pointing to a non existing location, a crash occurs with trying to save recording to bmr file |
| 654276 | Resolved a crash that occurs if recording a VBA to a specific location, which is not accessible to the user |
| 653551 | With VBA retrieving Dimensionstyle from element is raising a crash, if text font is automatically replaced due to missing rsc file |
| 655225 | Resolved an crash when applying a Saved View filter in specific file |
| 655351 | Resolved a crash after selecting named boundaries tool with specific dgn. |
| 655607 | Modifying Drawing Name value to match another existing one causes the Drawing Identifier value to be out of sync between Drawing Title and Properties dialog |
| 661539 | ]Color in Properties for filled shape shows as ' Varies Across ' - The Fill Color is not separated in the Color property as with previous versions |
| 658523 | The status of resizable/sortable columns in list boxes is automatically saved to user preference, the sort marker is showing wrong direction |
| 660377 | With large databases issues parsing table names using the function mdlDB_describeDatabase() |
| 657696 | Fixed crash with DGNLIB consisted of cell index attached, when placing a new cell index |
| 657227 | Resolved issue with blinking in elements is seen when doing RMB ->Level Off in Multi-selection mode. |
| 657284 | Fixed issue with Level color is not preserved in dgnfile, when it is modified for nested dwg reference from level manager dialog after Save As/Save Settings |
| 658041 | Fixed issue with specific .cel library files are crashing when opened in MicroStation |
| 658532 | Added Help documentation for Find and Replace Text Key-in amendment |
| 658503 | Resolved issue where adding Main toolbox would disappear after restarting in specific user case. |
| 655222 | Resolved a issue with generated level numbers are unique |
| 661617 | Resolved crash when editing a group of Item Type values through Properties dialog |
| 654642 | Corrected issue with specific file where insert fields area for Shapes in the file shows 0 Sq.m. |
| 654529 | Added addition settings and their descriptions to the Text Styles Dialog in the Spacing Tab |
| 659910 | Resolved issue where Excel Import had some row heights that are not matching with Excel row heights |
| 659911 | Fixed issue with Excel Import where some rows are showing excessive empty space at top of row after importing in specific file. |
| 660222 | Fixed issue with VBA where assigning new rotation matrix to text element does not honor text origin as pivot point |
| 658002 | Fixed issue with first time text is not getting placed with active color, when color is not defined in Text style in specific file |
| 655806 | Resolved issue with VBA where reassign Dataregion to Textnode subelements causes runtime error |
| 655731 | Fixed issue with Find and replace key-in is not working consistently in specific file |
| 684616 | Fixed issue with Special Characters do not display correct character. |
| 664833 | Resolved a Crash when editing Text placed with 'Swiss 721 Light BT' |
| 661004 | Fixed issue with Chinese font does not displaying correctly in Word Processor |
| 661017 | Resolved issue with the Arabic character display |
| 661027 | Specific RSC file causes crash when placed in MS_SYMBRSRC or MS_FONTPATH file pathway |
| 661036 | Resolved issue with adding words to dictionary when running spell checker that would cause MicroStation to freeze |
| 661045 | Resolved issue with a Users specific font resource file that would cause a crash |
| 661098 | Help page updated for Enter Data Fields |
| 661115 | Resolved issue with the Edit, then Place Text Active Angle |
| 661200 | Fixed issue where a user is unable to change case for the text placed inside the fence. |
| 661271 | Fixed issue with Text Field custom defined Units not visible in Fields Editor |
| 684799 | Resolved crash when using Solid Extrusion Along Path tool with Circular Profile in particular file |
| 661461 | Resolved crash if you try to create Tube Feature (Extrude Along Path, Circular Profile) outside of SWA in specific file |
| 653819 | Not able to select Multiple Solid for Cut Operation |
| 659221 | Improved time to place parametric cell if edit variable value when placing. |
| 698745 | Resolved a crash when selecting parametric cell to get property information in specific file |
| 679307 | Fixed a crash when you place attached specific cell file. |
| 656171 | Fixed issue with key frame, script and path animations not getting export to LumenRT correctly |
| 657332 | The new level becomes 0 level after saving |
| 658030 | Resolved specific crash with unique UPF |
| 653637 | Resolved an issue where the text is not wrapping correctly in specific file |
| 653520 | Fixed issue with Text spacing changes when saving DGN to DWG in specific file |
| 654801 | Resolved issue to support "Multiple" DWG line spacing type |
| 660394 | Fixed issue with Text contained in shared cell in DWG displaying incorrectly |
| 660496 | Resolved issue with Saving DGN to DWG where Rasters are not saved in the same output folder |
| 660351 | Fixed issue with external PDF attachments not displaying in DWG |
| 657354 | Resolved issue with DWG Viewport Rotated when opened as Sheet Model in specific file |
| 657371 | Fixed issue with specific DWG file causing a crash upon opening file |
| 655214 | Fixed issue with Treat Attachments as Element for Manipulation toggle is not working correctly |
| 655343 | Fixed issue with display elements in reference in preview when moving a cached drawing view not appearing correctly |
| 654302 | Resolved issue where Tags are not visible and scaling in specific file |
| 654307 | Reference Dialog Highlight Not Changed On Files After Display Is Toggled On / Off |
| 654309 | Fixed issue with Reference file is lost when attached with relative path on in specific user scenario |
| 654354 | Reference Merge into master file with patterns freezes MicroStation |
| 658059 | Redo command is not working after using Edit Text tool |
| 668891 | Reference attach a PDF with arabic text, causes a crash |
| 660797 | Resolved issue where screen resolution is set to 2736 x 1824 and Snap is not working, black cursor crosshair is invisible |
| 658228 | Resolve issue where Google Earth tools do not work. Google Earth Pro pushes updates to latest version 7.3.3 automatically and 32 bits does not synchronize anymore. |
| 658723 | Resolved issue where Angle filed in Accudraw not considering values in Radians/Gradians. |
| 659006 | Resolved issue where users would report random automatic mouse click when placing line by dragging mouse |
| 659882 | Fixed issue with Line Features that have a line-string Element Handler that resulted in a crash |
| 653665 | Resolved issue where Dimensions dropped after working in v7 workmode in v8i |
| 653613 | Fixed issue where Dimension text color not inherited when edited |
| 653633 | Fixed issue DimensionText color not correct in specific file |
| 654738 | Attaching SHP file to basemap.dgn gives error: Definition "Bentley.OgrECPlugin ECRepository Ref File Attachment Data Conversion" queries validation failed. |
| 654719 | Resolved issue where MicroStation is stuck when using ‘Capture Google Earth Image’ tool |
| 654987 | Fixed issue where User is not able to Access the Tools for Define Placement Tool in Geographic Tool Box |
| 659273 | Resolved issue where Item type's Expression Builder wont start when V8i task theme is on |
| 659884 | Fixed issue with Place Table from Excel command freezes on the Generating table pop up when placing a .xsls file |
| 658196 | Resolved issue with MicroStation results in a crash after Changing display from Wireframe to illustration in specific file |
| 656451 | Fixed issue when selecting an element with assigned material results in a crash in specific file |
| 695792 | Fixed issue with Fence File Copy not working as filled shapes which are clipped in Sheet view are not copied to new file |
| 654604 | Updated the Measure Distance Tool Setting Flatten Option to reflect GUI |
| 653468 | Resolved issue when converting multiple .dgn files to .stp files via batch exportation process |
| 655908 | Fixed issue with STEP Imports incomplete geometry and restored surfaces in specific file |
| 656082 | Resolved a crash when import specific STEP file |
| 656087 | Fixed issue in specific file where elements are missing from STEP files after import |
| 656088 | STEP files not Import correctly if we import the file in new model of another file. |
| 658201 | Resolved crash/hang while Importing given IGS files. |
| 659389 | Resolved issue with clip reference area result doesn't match with without clip reference area result. |
| 659393 | Fixed issue with Measure area tool by fence method does not show the result. |
| 660269 | Fixed issue with File Copy not working as filled shapes which are clipped in Sheet view are not copied to new file. |
| 658000 | Resolved issue where Explorer Links function continually navigates back to parent folder |
| 654700 | Corrected documentation for Explorer Search Report |
| 654673 | Resolved issue where a crash results with Item Types Import/Export in specific file |
| 656045 | Resolved issue with IFC Open /Import that does not show IFC Site geometry [Surface] |
| 656049 | Fixed issue with specific file that causes a hang on importing IFC file |
| 656157 | Resolved issue with opening specific IFC file results in a crash. |
| 657937 | Fixed issue with replacing cell (which doesn't have attached item), neither item is imported with cell nor item library propagate in item type manager |
| 661659 | Resolved issue when replacing cell (which already have item), attached item properties doesn't get updated |
| 661467 | Selection Type is not applicable with Filter of report during table placement |
| 675635 | Fixed issue with opening specific .ifc file causes a crash |
| 673670 | Fixed issue with Excel lookup is not working with "(*.xlsm) excel file format" when select as a Picklist source |
| 684736 | Resolved issue with Point cloud conversion fails when selecting multiple files and setting Multiple Output to Yes |
| 653515 | Resolved specific file that would result in a crash |
| 655283 | Resolved a crash after error message while Save As with specific dgn |
| 656106 | Resolved an issue when Shrinkwrap tool is used for high Level of Detail that resulted in a crash |
| 656552 | Resolved issue with '-S' switch is not working without '-M' Switch |
| 656454 | Fixed crash when opening a certain V7 file |
| 656470 | Resolved a hang on fit view when Xgraphic elements in a specific file that contains ACIS solids as subelements |
| 657616 | Resolved issue with changing Color Table back to Default is not saving to DGN Files Previously Converted From V7 DGN |
| 679130 | Resolved issue when opening a specific DGN file that resulted in a crash |
| 658548 | Updated help for Imprint block states "to define the first point of the circle" rather than "to define the first point of the block" |
| 654723 | Resolved issue where MicroStation shuts down when printing pdf with specific pltcfg driver properties |
| 654883 | Fixed issue with Link to Google maps location does not display marker and location information |
| 654748 | Resolved issue with specific file where a you are unable to produce 3D PDF from DGN file |
| 654753 | Deliver new PDF.PLTCFG drivers for improved quality and performance settings |
