| Product(s): | MicroStation Connect | ||
| Version(s): | 10.14.02.01 and higher | ||
| Environment: | Windows 10 | ||
| Area: | Exception | ||
| Subarea: | N\A |
Startup Logs
To troubleshoot Product Startup performance issues, Bentley Technical Support may request for Startup Logs
1. Create a Windows System Environment variable MSENV_LOGSTARTUP and set it to ‘1’ or ‘true’.
Start > Control Panel > System > Advanced System Settings
2. Start MicroStation Connect Edition and open a design file
3. From Ribbon open the KEYIN dialog
4. Enter key-in “SHOW STARTUP C:\temp\Startup1.log” (Note the destination folder must exist. if not a DOS window will appear with the log information)
5. Send the captured log to Bentley Technical Support via Service Request created on your behalf
If required repeat process and sequence log name Startup2.log and share
Once the logs have been captured, close MicroStation and delete the Windows System Environment variable MSENV_LOGSTARTUP
Video
Slow file open performance over Wi-Fi
| Original Author: | Leonard Jones |
