| Version(s): | 10.16.01.319 | ||
| Area: | Exception | ||
| Subarea: | N\A |
MicroStation crashes on start up
Ideally collect the following, log a Service Request and work with the Support team in troubleshooting the issue.
• Crash logs - check video
• Event logs - check video
From the crash logs it was noted an old License client was being used. Upgrading to the latest version of Connection Client fixed this issue.
Exception: 0xc0000005 @ 0x00000000
0: 000000d7c4dfe110 00007ffa9583fbc0 0000000000000018 000002a73101fb20 0000d4bd3e48e5ca 0000000000000001 <nosymbol>
1: 000000d7c4dfe180 00007ffa9583a5c9 000000d7c4dfe2a0 0000000000000000 000000d7c4dfe2d0 000000d7c4dfe2d0 Bentley::SelectServer::Client::DbLogShardHandler::UsageExists+0x124e0
2: 000000d7c4dfe210 00007ffa95838b31 000000d7c4dfe230 000002a73101fb20 000002a7519ab880 000002a73101fbb0 Bentley::SelectServer::Client::DbLogShardHandler::UsageExists+0xcee9
3: 000000d7c4dfe250 00007ffa9583f6de 000002a74def5e70 00007ffa9590d760 00000000ffffffff 0000000000000000 Bentley::SelectServer::Client::DbLogShardHandler::UsageExists+0xb451
4: 000000d7c4dfe300 00007ffa95811463 000002a7586bbd10 00000000000909c4 00000000000003e8 00007ffa9590d760 Bentley::SelectServer::Client::DbLogShardHandler::UsageExists+0x11ffe
5: 000000d7c4dfe380 00007ffa958147b5 000002a7586bbd10 000000d7c4dfe490 00000000ffffffff 00007ffa9591eed8 <nosymbol>
6: 000000d7c4dfe4d0 00007ffa9581d81f 00000000000909c4 00007ffa000003e8 000002a749a991a0 0000000000000000 Legacy_LicenseClient_StartLicense+0x269
7: 000000d7c4dfe580 00000000595d1063 00000000000909c4 0000000000000000 00000000000003e8 00000000000909c4 LicenseClient_StartLicense+0x18f
8: 000000d7c4dfe830 0000000059adb3d7 00007ffaba3b40e0 000002a74d1e4780 000002a74e1b2518 000002a74d1e4780 mdlModelIterator_setAcceptCellsOnly+0x663
9: 000000d7c4dfe890 0000000059ada6bb 00007ffaba3b40e0 000002a74d1e4780 00007ffaba3b40f8 00007ffaba3b40f8 Bentley::MstnPlatform::ISessionMgr::SetSnapsPopupGroupKeyin+0x1b97
10: 000000d7c4dfe930 0000000059adc6c7 000002a74d1e4780 00007ffaba3b40f8 000002a74decdbb8 000002a74d1e4780 Bentley::MstnPlatform::ISessionMgr::SetSnapsPopupGroupKeyin+0xe7b
11: 000000d7c4dfe9b0 0000000059b68e7d 000002a74cc9ffa0 00000000000008a8 00007ffaba3b40f8 000002a72f67271c mdlSystem_recordUserActivity+0x427
12: 000000d7c4dfebf0 00007ff6ff75600c ffffffffc6011044 00007ff6ff750000 000002a72f737c00 0000000000000001 win32Intface_winMain+0x17d
How to Download the CONNECTION Client
How to Install the CONNECTION Client
| Original Author: | Leonard Jones |
