| Version: | V8i, CONNECT | ||
| Area: | Sheet Composition | ||
| Subarea: | Annotation Scale |
Attach the same reference into a model multiple times at different scales but keep the size of the text in the reference the same size
After designing a project within a Design Model it would be required to reference this design in a Sheet Model for output. To present the project in the best manner the Design Model could be referenced into the Sheet Model a number of times at different scales. However, in doing this, the text from the Design Model also scales displaying it a different size with each reference. This may conflict with drawing standards. Is it possible to display the text at one size throughout the sheet no matter what scale it has been referenced at?
Using an Annotation Scale may be a solution for this type of issue
Usability of Annotation Scales
| Original Author: | Conor King |
