Product: | MicroStation | ||
Version: | CONNECT Edition | ||
Environment: | N\A | ||
Area: | DWG | ||
Subarea: | Open |
After installing Civil 3D 2022 object enabler the following message appears in the message center when opening DWG files with Civil 3d proxy elements:
Failed loading module c:\program files\autodesk\civil 3d 2022 object enabler\aeccvbase.dbx!
1. Install Civil 3D 2022 object enabler from Autodesk website at https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autodesk-civil-3d-2022-object-enabler.html
2. Launch MicroStation CONNECT Edition and then open the DWG file that contains the Civil 3D 2022 proxy elements
3. Observe the Message Center
The reactor load messages in the message center are incorrect due to an internal issue in the Object Enabler itself. Please ignore this message as the object enabler has installed correctly even though the this message is received.
Original Author: | Regie Wallace |
