| Version(s): | V8 2004 Edition | ||
| Area: | Detailing Symbols | ||
| Subarea: | XYZ Text | ||
The export coordinates tool from the XYZ Text tools are exporting the ACS values of the coordinates instead of the design coordinates.
Use the key-in: export useacs off, before exporting the coordinates.
